Running DC and Loco…
Running DC and LocoFi trains on one layout – wiring help
(@steve)
Forum admins asked if I could post some information about my track wiring for my small layout where I run both DC and LocoFi trains.
I have a 2-Cab system with 8 power blocks (2 are for yards). I have 3 different DC transformers and a 12 volt clean power supply for LocoFi. I have two transformers on Cab A and then the 12 Volt pack and another DC Transformer on Cab B, so I can select one from each side. The layout is small (4×8) so managing multiple trains across blocks is a challenge (less so with LocoFI when the 12Volt power is enabled on all blocks!!). I can also run DCC trains with an MRC Tech 6 dual mode transformer that is connected as one of the options on Cab A.
Best info I could pull from my files:
https://www.dropbox.com/scl/fi/yhdt6lgflvslimkxhzzl4/public-copy-HO-DC-wiring-scheme-May-2017-with-updates.pdf?rlkey=aq9yrfn8kd0oq6lhls9l8tp6d&dl=0
This might also help:
https://www.thesprucecrafts.com/wiring-model-railroad-for-block-operation-2381862#:~:text=Hooking%20up%20the%20Wires&text=For%20two%2Drail%20blocks%2C%20run,power%20from%20the%20two%20cabs
Posted : September 18, 2023 2:35 pm
Thank you so much for sharing this information Steven!
All, This is a great example of running LocoFi alongside not only DC but also DCC! Here’s glimpse of trains running on Steven’s layout.
Posted : September 18, 2023 2:40 pm
