<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									Operation and sounds from an electric locomotive - Electric				            </title>
            <link>https://forum.wifimodelrailroad.com/forum/electric/operation-and-sounds-from-an-electric-locomotive/</link>
            <description>Share, discuss new ideas, innovative ways you have used LocoFi™ and ask questions.</description>
            <language>en-US</language>
            <lastBuildDate>Tue, 21 Apr 2026 13:01:03 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>RE: Operation and sounds from an electric locomotive</title>
                        <link>https://forum.wifimodelrailroad.com/forum/electric/operation-and-sounds-from-an-electric-locomotive/#post-435</link>
                        <pubDate>Sat, 17 Sep 2022 20:52:58 +0000</pubDate>
                        <description><![CDATA[@DandelionThank you for your input. Excellent information!
&nbsp;
Here&#039;s another type of &quot;notching&quot;.
&nbsp;
&nbsp;
&nbsp;
In the following, you can hear two distinctive sounds:
&nbsp;...]]></description>
                        <content:encoded><![CDATA[<p class="wpf-reply-mention" data-autoprepended="1"><a class="wpf-reply-mention-link" href="https://forum.wifimodelrailroad.com/participant/info/">@Dandelion</a></p><p>Thank you for your input. Excellent information!</p>
<p>&nbsp;</p>
<p>Here's another type of "notching".</p>
<p>&nbsp;</p>
<p><a href="https://www.youtube.com/watch?v=T0R_28XbieY&amp;ab_channel=TCRail" rel="nofollow">https://www.youtube.com/watch?v=T0R_28XbieY&amp;ab_channel=TCRail</a></p>
<p>&nbsp;</p>
<p>&nbsp;</p>
<p>In the following, you can hear two distinctive sounds:</p>
<p>&nbsp;</p>
<p><a href="https://youtu.be/awclpPOWLbw?t=186" rel="nofollow">https://youtu.be/awclpPOWLbw?t=186</a></p>
<p>&nbsp;</p>]]></content:encoded>
						                            <category domain="https://forum.wifimodelrailroad.com/forum/electric/">Electric</category>                        <dc:creator>Admin</dc:creator>
                        <guid isPermaLink="true">https://forum.wifimodelrailroad.com/forum/electric/operation-and-sounds-from-an-electric-locomotive/#post-435</guid>
                    </item>
				                    <item>
                        <link>https://forum.wifimodelrailroad.com/forum/electric/operation-and-sounds-from-an-electric-locomotive/#post-434</link>
                        <pubDate>Sat, 17 Sep 2022 18:25:47 +0000</pubDate>
                        <description><![CDATA[The simple way, you can cheat a little and look at other manufacturers&#039; results.
Here is a Amtrak AEM-7 with many sounds and a lot of lights too.
&nbsp;
Something like that with WiFi woul...]]></description>
                        <content:encoded><![CDATA[<p>The simple way, you can cheat a little and look at other manufacturers' results.</p>
<p>Here is a Amtrak AEM-7 with many sounds and a lot of lights too.</p>
<p><span>https://www.youtube.com/watch?v=Q-VpYfo6saI</span></p>
<p>&nbsp;</p>
<p>Something like that with WiFi would perhaps be a strong advantage over the competitors' possibilities.</p>
<p>&nbsp;</p>
						                            <category domain="https://forum.wifimodelrailroad.com/forum/electric/">Electric</category>                        <dc:creator>Dandelion</dc:creator>
                        <guid isPermaLink="true">https://forum.wifimodelrailroad.com/forum/electric/operation-and-sounds-from-an-electric-locomotive/#post-434</guid>
                    </item>
				                    <item>
                        <link>https://forum.wifimodelrailroad.com/forum/electric/operation-and-sounds-from-an-electric-locomotive/#post-433</link>
                        <pubDate>Sat, 17 Sep 2022 15:10:14 +0000</pubDate>
                        <description><![CDATA[In older electric locomotives throttle is notched too, different stages switches on/off resistors by contactors or rotary circuit breakers, or mostly like in alternating current locomotives,...]]></description>
                        <content:encoded><![CDATA[<p>In older electric locomotives throttle is notched too, different stages switches on/off resistors by contactors or rotary circuit breakers, or mostly like in alternating current locomotives, different stages from the main transformer is selected.</p>
<p>Nässjö Järnvägsmuseum, Da loket provköres juni 2016,</p>
<p>https://www.youtube.com/watch?v=w4aZk9dII2E</p>
<p>&nbsp;</p>
<p>Newer locomotives or trainsets, continuously varying slider and electronic power control.</p>
<p>Some of them emitting a "frequency converter sound", some others are very quiet in the drive unit.</p>
<p>SJ Snabbtag dubbeltag mot Malmo avgar fran Stockholm (X2000),</p>
<p>https://www.youtube.com/watch?v=Fk-5UoWKEwQ</p>
<p>&nbsp;</p>
<p>From the outside there is clearly a different sound comming from them. But normaly I think nearly every sound is masked by the masive cooling fans. Occasionally there is compressor and brake sounds to be heard. From the drivers cabin you can clearly hear the difference between old/new locomotives. Outside, you have to be very close to the locomotive to hear contactors or humming power electronics, I think.</p>
<p>&nbsp;</p>
<p>Some older DC resistor locomotives, like in this example. the South African 6E1, the blower starts/stops depending on the throttle setting or/and the heat build up in the shunting resistors. This would be simple to emulate with a long sample that isn't changing pitch and gets looped. If it's long enough, it's hard to tell it's just looping over and over.</p>
<p>Last of the South African class 6E1's Part Three,</p>
<p>https://www.youtube.com/watch?v=RSOvZsFkmxY</p>
<p>&nbsp;</p>
<p>Every locomotive is unique, so it's best to try to get/make soundfiles for "your" locomotive. All depends on how far to take it. Any generic soundfile is good enough. But some users might want to do it very realistic as far as possible. With LocoFi we can do whatever we want with the sound, for free, no costly programmer or messy user software which may take days to learn. Just a wav file, slide in the SD-card and off we go!</p>
<p>&nbsp;</p>
<p>I think just the basic behaviour of what we want from the sound file is needed in the firmware/APP. Like for the running sound, constant pitch, speed following pitch. Loop or no loop for additional sounds, like bell needs looping, a coupler sound or compressor needs no loop. Start up and shut down time adjusted to the sound lenght.</p>
<p>&nbsp;</p>
                        <guid isPermaLink="true">https://forum.wifimodelrailroad.com/forum/electric/operation-and-sounds-from-an-electric-locomotive/#post-433</guid>
                    </item>
				                    <item>
                        <title></title>
                        <link>https://forum.wifimodelrailroad.com/forum/electric/operation-and-sounds-from-an-electric-locomotive/#post-432</link>
                        <pubDate>Sat, 17 Sep 2022 13:52:20 +0000</pubDate>
                        <description><![CDATA[I will post my thoughts and results here and in the installation section soon.Waiting for my X2000 train to arrive, my first electric canidate for being LocoFied.]]></description>
                        <content:encoded><![CDATA[<p>I will post my thoughts and results here and in the installation section soon.</p><p>Waiting for my X2000 train to arrive, my first electric canidate for being LocoFied.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.wifimodelrailroad.com/forum/electric/operation-and-sounds-from-an-electric-locomotive/#post-432</guid>
                    </item>
				                    <item>
                        <title>Operation and sounds from an electric locomotive</title>
                        <link>https://forum.wifimodelrailroad.com/forum/electric/operation-and-sounds-from-an-electric-locomotive/#post-431</link>
                        <pubDate>Sat, 17 Sep 2022 01:20:17 +0000</pubDate>
                        <description><![CDATA[We&#039;re working on introducing a new &#039;engine type&#039; that is electric. As such we need to model it&#039;s operation as well as associated sounds.
&nbsp;
This is what we know or have observed:
                        <content:encoded><![CDATA[<p>We're working on introducing a new 'engine type' that is electric. As such we need to model it's operation as well as associated sounds.</p>
<p>&nbsp;</p>
<p>This is what we know or have observed:</p>
<ol class="o8mjA _4OSHH">
<li class="YPH8D" dir="auto">
<p id="viewer-f492p392" class="SpiL2 kjztB _4OSHH wHFxW" dir=""><span class="G7Gjj"><span>Throttle isn't notched. It's a lever that seems to work like a continuously varying slider.</span></span></p>
</li>
<p id="viewer-d2j3j1100" class="SpiL2 kjztB _4OSHH wHFxW" dir=""><span class="G7Gjj"><span>There is a slight hum of the motor that seems to increase in pitch as the throttle is increased. Not loud prime mover sounds like that of a diesel locomotive but a light hum of an electric motor.</span></span></p>
</li>
</ol>
<p>It'it has been suggested in another thread that there's also a constant blower sound.</p>
<p>&nbsp;</p>
<p>We're looking for inputs possibly with examples as to what the prototypical operation of an electric locomotive would like. There's possibly variations in different electric types too. We would like to consider all suggestions.</p>
<p>&nbsp;</p>
<p>Thank you.</p>
                        <guid isPermaLink="true">https://forum.wifimodelrailroad.com/forum/electric/operation-and-sounds-from-an-electric-locomotive/#post-431</guid>
                    </item>
							        </channel>
        </rss>
